Mikey94025
Sep 25, 2016Hero
Intermittent internet connectivity outage with Orbi?
I just installed my new Orbi router yesterday, replacing a Nighthawk R8500. I believe that overall wireless coverage has improved, though top-end performance is not quite as high (measured via fast....
- Sep 29, 2016
I read in the other "Ring Door Bell" thread that a customer had better results after disabling "Enable Implicit BEAMFORMING". So I tried that just to see what happens. It's probably too early to tell yet, but my 2 Nest cameras have only disconnected once in the past 2 days and I think that's because there was a power outage at my house today (I wasn't home and both cameras went out at the same time, something the intermittent outages haven't done).
dsc_dewain
Oct 14, 2016Guide
I too have had random disconnects off the network, the laptop is hard wired to the router, the disconnects to appear for some reason late morning, and some times at night. May be other times, but just haven't noticed.
- dsc_dewainOct 14, 2016Guide
Just adding log lines, the time stamps appear to be 4 hours off, not sure where to fix that.
Not sure if the 'attacks' are causing issues.
[DoS Attack: ACK Scan] from source: 31.13.69.226, port 443, Friday, October 14, 2016 07:33:21
[DHCP IP: 192.168.1.12] to MAC address f8:f1:b6:d9:b2:ce, Friday, October 14, 2016 07:30:43
[DHCP IP: 192.168.1.10] to MAC address ac:3c:0b:38:44:07, Friday, October 14, 2016 07:30:28
[admin login] from source 192.168.1.112, Friday, October 14, 2016 07:23:36
[DoS Attack: ACK Scan] from source: 199.4.160.29, port 443, Friday, October 14, 2016 07:12:55
[DoS Attack: SYN/ACK Scan] from source: 206.190.57.61, port 443, Friday, October 14, 2016 07:12:45
[DoS Attack: ACK Scan] from source: 199.4.160.29, port 443, Friday, October 14, 2016 07:10:53
[DoS Attack: SYN/ACK Scan] from source: 92.222.85.168, port 80, Friday, October 14, 2016 06:49:30
[DoS Attack: ACK Scan] from source: 31.13.69.195, port 443, Friday, October 14, 2016 06:43:12
[DHCP IP: 192.168.1.112] to MAC address ec:f4:bb:1b:19:82, Friday, October 14, 2016 06:42:35
[DoS Attack: ACK Scan] from source: 31.13.69.195, port 443, Friday, October 14, 2016 06:41:57
[DHCP IP: 192.168.1.4] to MAC address a0:04:60:0e:a9:b4, Friday, October 14, 2016 06:11:21
[DHCP IP: 192.168.1.22] to MAC address 90:02:a9:69:d6:09, Friday, October 14, 2016 06:00:33
[DoS Attack: TCP/UDP Chargen] from source: 185.94.111.1, port 58473, Friday, October 14, 2016 05:56:28- peteytestingOct 14, 2016Hero
dsc_dewain wrote:Just adding log lines, the time stamps appear to be 4 hours off, not sure where to fix that.
[DoS Attack: TCP/UDP Chargen] from source: 185.94.111.1, port 58473, Friday, October 14, 2016 05:56:28the dos attacks are more than likley dead torrents you have downloaded then closed , if there is lots it could swamp the nat table
