Mikey94025
Sep 25, 2016Hero
Intermittent internet connectivity outage with Orbi?
I just installed my new Orbi router yesterday, replacing a Nighthawk R8500. I believe that overall wireless coverage has improved, though top-end performance is not quite as high (measured via fast....
- Sep 28, 2016
I read in the other "Ring Door Bell" thread that a customer had better results after disabling "Enable Implicit BEAMFORMING". So I tried that just to see what happens. It's probably too early to tell yet, but my 2 Nest cameras have only disconnected once in the past 2 days and I think that's because there was a power outage at my house today (I wasn't home and both cameras went out at the same time, something the intermittent outages haven't done).
Netwizzerd
May 29, 2017Tutor
Hi all -
Ever since my Orbi router auto-updated its firmware back on 5/22/2017 to the latest version 1.10.1.2 the two Apple TV 4th gen units I have in my house are essentially non-functional. Constant connect/re-connects, insanely slow speeds during the periods the Apple TV shows it's connected. I also have two Apple TV 2nd gen units in my house...no issues with them at all. I have a couple of NEST cams, a ring floodlight cam, and several other IOT devices in the house. As far as I can tell no issues with any of them since the firmware upgrade.
My first thought to get the 4th Gen Apple TV's working again was to downgrade the firmware, until I noticed that the Orbi will just auto-update itself back to the current version. There is no setting to disable auto-updating of firmware...crazy!
Just curious if anyone else has experienced issues since 1.10.1.2 release?
As most of you already know, both beamforming and MU-MIMO are disabled by default.
I tried lowering the power level on the 2.4Ghz radio to 50% and down to 25%, but no change. Also tried scheduling the 2.4Ghz radio to go OFF according to a time schedule where it was basically off 24/7, but no luck there either.
I agree with others who have posted....every minute I have to spend trolling forums and tweaking with my advanced settings is one more minute I'm regretting my decision to buy the Orbi system. If I'd purchased a $95 D-Link I'd be more understanding, but given the Orbi's price point these types of issues shouldn't exist.
Would appreciate any insight......
- marshymallowMay 30, 2017ApprenticeI propose you try and get hold of the latest Beta FW which I have have personally experienced much improvements. Not perfect as yet but alot less hair tearing situation. Plus I can still at least have MU-MIMO activated with very reasonable performance. With many devices connected, MU-MIMO is a must have. Bean Forwarding is not crucial.
- DrCalJun 02, 2017Star
I hear you Netwizzerd! Same here. I am so naive thinking spending more $ would get a quality and more robust product. Wrong! Since I bought this junk, nothing but trouble, tech support is a joke. All Macs are not working properly, some (e.g. MBP) simply not working at all.
- cpaz7801Jun 13, 2017Initiate
Sorry, no insights here... Just another user with the exact same situation.
Since I've installed the ORBI I have good coverage and great speeds on all my devices... except the Apple TVs 4th generations that connect extremely slow and constantly drop the signal. This happens every 20 minutes or so and takes up to 5-10 minutes to reconnect... try watching a TV show like that!
ATV 4th gen only device with issues. I've measured speed on my iPad Pro positioned right next to the ATV: iPad Pro = 100Mb/s, ATV: 1-2 Mb/s.
Any help will be appreciated,
