Mikey94025
Sep 25, 2016Hero
Intermittent internet connectivity outage with Orbi?
I just installed my new Orbi router yesterday, replacing a Nighthawk R8500. I believe that overall wireless coverage has improved, though top-end performance is not quite as high (measured via fast....
- Sep 28, 2016
I read in the other "Ring Door Bell" thread that a customer had better results after disabling "Enable Implicit BEAMFORMING". So I tried that just to see what happens. It's probably too early to tell yet, but my 2 Nest cameras have only disconnected once in the past 2 days and I think that's because there was a power outage at my house today (I wasn't home and both cameras went out at the same time, something the intermittent outages haven't done).
Netwizzerd
Jun 21, 2017Tutor
Noticed there is a new firmware version available now. Has anyone tried installing? If so, does it address this issue we're all having?
- mikebeesJun 22, 2017Guide
New software V1.11.0.20 ... does not solve connection issues - test time 1 hour. Will post if longer running yeids different results.
I just tried it. Rebooted camera and the camera still goes offline.I might let it run a little while longer to see if it keeps happening. So far the beta software was the best
- darrylk1Jun 22, 2017Initiate
I installed the beta (1.11.0.2-dbg1) on May 29, the first few hours were a mess, worse than ever, then it settled down and has been running ever since with only a few minor hiccups.
- mikebeesJun 26, 2017Guide
CLARIFICATION :
Below are two different tests. The Images are different. I had about 16 outages of about 15 mins each in a day with
V1.11.0.20. I am now trying beta (1.11.0.2-dbg1). The V1.11.0.20 was better than what I had before but still not acceptatble. I reported that I was experinceying the same behavior as darrylk1 ... but I was on a different software image. We will see how the beta image goes.
MY PREVIOUS POST:2017-06-22 12:01 PM
darrylk1 beta (1.11.0.2-dbg1) on May 29, the first few hours were a mess, worse than ever, then it settled down and has been running ever since with only a few minor hiccups.
