RustyShano
Feb 01, 2018Guide
Intermittent internet connectivity outage with Orbi?
Firstly, while I do have a satellite also, this issue has nothing to do with that. No Wifi is involved here. The PC is wired directly to the Orbi. We upgraded out Xfinity service to 1gigabit/45m...
Apr 11, 2018Guru - Experienced User
What FW are you using on the router?
Have you factory reset the router and run a quick speed test with out setting up the router or if you set up the router, don't configure or do anything with the speedtest under QoS or parentacl controls?
If you use the modem in router mode, you can use the DMZ on the modem for the Orib router as a suggestion. Just disable uPnP on the modem.
Besure LAN cabling is of good quality. CAT6 recommended.
Test with different browsers, IE11, FF and Opera to see if there is any differences.
Disable any PC security software temporarily as well and test.
