Wamphyri
Jul 12, 2019Aspirant
intermittent internet dropouts RBK50
I have been suffering intermittant internet issues for a while now and i was hoping that the latest firmware update would have made a differnce but it hasn't :( here is a log from the last 3 days...
Jul 12, 2019Guru - Experienced User
This happening with wireless and wire connected devices?
Try a factory reset on the RBR and setup from scratch.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Wamphyri
Hi Thanks for the response.
i've answered a numbe rof the points below, but the issue is not a wireless issue the disconnect log is from a hard wired machine direct into the Orbi. I've been looking at the logs but not much in there and as its intermittant its difficult to capture the point of disconnect. (only after).
ideally I'd like to get the equivalent of a windows sysem log output to see whats happening at the point of failure. from what is happening it seems more like the WAN interface is resetting but like i said without being able to look at log files at the point of failure its impossible to tell.
I'm going to fire up an external machine an run a test the opposite way to see if that helps with the investigation as I have a static IP from my ISP.
Vodafone ISP Modem - Technicolor TC440VDF HW Ver 3.6.0
Affects only the internet connection wireless internal device connection works
-Done this previously
What is the size of your home? Sq Ft? -
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. - approx 25ft on different floors
a couple but as mentioned not really a wireless issue
