intermittentweb
Aug 13, 2019Aspirant
Internet Access Fine for Hours, but Always Ends Up Partially Dying (Spectrum Internet)
Issue: I can access a website: ex: engadget.com just fine after my Orbi is reset. After a few hours, I stop being able to access the website. (I can still access that website via my phone's cellu...
intermittentweb
Orbi Firmware is V2.3.5.30
Cable Modem model is Spectrum E31U2V1
Problem appears for both wireless and wired connections, yes. I have tried moving the satellite closer, as well as have disconnected the satellite with no change.
Appreciate the help.
Aug 13, 2019Guru - Experienced User
I would try this, turn OFF the RBS for a while. Just run the RBR.
See if the problem still appears.
Possbible issue with the modem. Has the ISP checked the signal quality up to the modem?
Be sure there are no coax cable line splitters between the ISP modem and ISP service box.
Swap LAN cables between the ISP modem and RBR. CAT6 recommended.
- intermittentwebAug 13, 2019Aspirant
There are multiple other wifi networks nearby as we live in an apartment.
The signal strength and signal levels of the modem are really good according to Spectrum. There is no splitter as the signal goes directly.
I will test the unplugging of the RBS and replacing the cables. I think it is unlikely cabling is the issue given that the internet works again after an Orbi reset. Unless faulty cabling is leading something to get into a faulty/stuck state.
Do you know of a network diagnostic tool suite that will enable further debugging?
Thanks again
- FURRYe38Aug 13, 2019Guru - Experienced User
Ok, if you have lots of near by wifi neighbors, this could be another cause. Wifi congestion in your surroundings could be causing the router to stop and try to reboot and not find a clear channel to use for WiFi.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Also try lowering the power output of the RBR from 100% to say 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
