user_error
May 16, 2019Tutor
Internet Connection Drops - Re-Enabled by Testing or Renewing Ip
Hey All - I get disconnected from the internet (sometimes multiple times) daily and have noticed that if go to Home > Internet > Test OR Advanced Home > Connection Status > Renew, I will generally ge...
May 16, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the router is connected too?
zyxel hla 3000 (Frontier FiOS)
The zyxel HLA3000 is (i believe, I don't have one) and ethernet coax bridge device. What router/modem is connected to the other end of it?
- ekhalilMay 16, 2019Master
Please try reducing the lease request time and see if that will give you an improvement:
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
- Enter the following commands:
- root@RBR50:/# config get wan_lease — Should give you --> 86400which means 24 hours
- root@RBR50:/# config set wan_lease=1800
- root@RBR50:/# config commit
- user_errorMay 16, 2019Tutor
Thank you - I've set the config per your recommendation and will post an update later.
- user_errorMay 17, 2019Tutor
Ok, internet just dropped again - seems to be an improvement though - that's over 24 hours w/o having to manually renew the IP. When I went to renew the IP, the lease was only nine minutes old (according to the Connection Status screen):
Lease Obtained 0 Days, 0 Hours, 30 Minutes Lease Expires 0 Days, 0 Hours, 21 Minutes What's the impact of continuing to reduce the lease time (although failing after nine minutes seems really short)?
- ekhalilMay 17, 2019Master
Yes, I think you should try further reducing the time.
Currently I'm using the value 750 in my Orbi and that is giving me good performance.
You can even try 500 directly.
- mhbethanyAug 04, 2020Aspirant
I'm unable to telnet into my Orbi. I get an error message when I try. Any other way to accomplish this? I have an RBR40.
Thanks for the reply - that zyxel hardware is connected via coax to an ONT (Optical Network Terminal?) which appears to be an Arris ONT1000-PS1-2G-SFU, Rev A, FW Rev B.
