user_error
May 16, 2019Tutor
Internet Connection Drops - Re-Enabled by Testing or Renewing Ip
Hey All - I get disconnected from the internet (sometimes multiple times) daily and have noticed that if go to Home > Internet > Test OR Advanced Home > Connection Status > Renew, I will generally ge...
May 16, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the router is connected too?
zyxel hla 3000 (Frontier FiOS)
The zyxel HLA3000 is (i believe, I don't have one) and ethernet coax bridge device. What router/modem is connected to the other end of it?
user_error
May 16, 2019Tutor
Thanks for the reply - that zyxel hardware is connected via coax to an ONT (Optical Network Terminal?) which appears to be an Arris ONT1000-PS1-2G-SFU, Rev A, FW Rev B.
