TheFinalProphet
Mar 15, 2021Guide
Internet connection drops forcing renew IP lease to resume working
I am having the EXACT same problem as the one found in this thread (https://community.netgear.com/t5/Orbi/Internet-Connection-Drops-Re-Enabled-by-Testing-or-Renewing-Ip/td-p/1752137). Sadly it was cl...
- Mar 18, 2021
Well, I finally fixed by problem. For the last several weeks, I have had the RBR750 drop internet connection. It would drop the connection after 24 hours since I rebooted the router. I figured out that the problem was when the IP address lease was up the router would stop working. The router was not renewing the IP address lease correctly or effectively. Once internet access would drop, I'd just log into the router and release and renew the IP address manually and the internet would magically work again fine. Something had to change over the last few weeks as this router was working great from May 2020 to just a few weeks ago. I tried everything, upgraded to latest firmware (3.2.17.12) since I was previously on 3.2.16.22, resetting to factory settings and setting up router again from scratch, and trying everything. Sadly, the suggestion on other threads to telnet in and reset the IP address lease time to shorter was unable to be done since I couldn't get telnet to work.
Well, after trying a lot of other things, I decided to downgrade the firmware to a version prior to the one I was using as outlined above. I downgraded to version 3.2.16.6 and have not had one issue since. The router has been up for over 24 hours now and already successfully renewed it's IP address lease on it's own without intervention. This fully solved everything.
Sadly, I think there is a bug in the newer firmware versions that caused a problem with IP address lease renewal. Nothing including factory reset fixed the issue until I downgraded firmware. Hopefully this gets fixed in an update so that I can have the other bug fixes as well, just not new bug introductions.
Hope this helps someone else who finds it. Suprised not more issues have been reported, but then again, maybe not a lot of people upgrade firmware religiously.
TheFinalProphet
Mar 15, 2021Guide
Thanks so much for the quick reply. On my Orbi RBR750, I can fix the issue by releasing and renewing my IP address lease by doing one of two things. I can either open up 192.168.1.1 and clicking advanced, connection status, then release and renew OR setup, internet setup, and test without changing anything. Both work to manually release and renew the IP address lease.
The internet works fine for the first 24 hours after doing this or rebooting the router, but as soon as the router should have renewed the IP address lease (24 hours is my ISP default renewal time) then it drops connection until you manually do this.
Regarding the computer, (and no worries for being literal at all), if I unplug the LAN port from my wall that is connected to the ONT and plug it into my computer directly, the problem is instantly fixed for my computer. If I replug it into the ORBI it is also fixed (but that basically forces a renew and release and so would obviously fix the issue).
I have not left the computer plugged directly into the ethernet to ONT for 24 hours. I really can't do that since my family would kill me with having nothing connected to the router. The natives are already upset when I get home and the internet is down again.
It is becoming a huge pain when I'm out of town as I cannot manually reset this or remote in to fix it. I also lose internet camera and alarm access and that's not good at all.
CrimpOn
Mar 15, 2021Guru - Experienced User
TheFinalProphet wrote:Regarding the computer, (and no worries for being literal at all), if I unplug the LAN port from my wall that is connected to the ONT and plug it into my computer directly, the problem is instantly fixed for my computer. If I replug it into the ORBI it is also fixed (but that basically forces a renew and release and so would obviously fix the issue).
I agree completely. My domestic happiness is directly related to internet connectivity.
"Desperate Times call for desperate measures" (Hippocrates). You could connect the Orbi router to a Smart Plug that is set to power off the Orbi router at some arbitrary time (such as 3am) and power it back on again at 3:01am. I have verified that the schedule in Smart Plugs (at least for TP-Link Kasa) is actually kept on the plug itself. At 3am, the router would power cycle, get a new DHCP lease and be good until the next 3am.
- TheFinalProphetMar 15, 2021GuideThanks for the info about the plug with memory kept on plug. Hopefully it won’t come to the bandaid type fix of unplugging and replugging nightly even if automated. It shouldn’t be like this. It was fine and working great May 2020 through until a few weeks ago. No change on my end but maybe I should try downgrading firmware in case it auto updated. I was hoping there was a fix outside of daily restart even if automated. Any idea how to get telnet access now if debug menu doesn’t list it anymore? Anyone else have any other thoughts?
