hisself
Jan 10, 2021Star
Internet Connection issues wired and wifi
I have two PCs wired through a switch to my Orbi RBR50. In both wired and wifi modes, the PC's show connected to the router, but say No Internet. Simultaneously, all my other devices are connected, o...
CrimpOn
Jan 10, 2021Guru - Experienced User
Does the wired connection say, "Unknown Network" or "No Internet"?
What happens when you "Troubleshoot" the ethernete connection?
- hisselfJan 11, 2021Star
The wired connection says Connected - no internet. At the same time, other wired PCs say Internet access.
I did some troubleshooting and discovered that the ethernet cable was loose at the router. It is working now, but tomorrow I will change the plugs on both ends of the cable.
I still do not understand why the WiFi connects to my router, but has no Internet. . .
