hisself
Jan 10, 2021Star
Internet Connection issues wired and wifi
I have two PCs wired through a switch to my Orbi RBR50. In both wired and wifi modes, the PC's show connected to the router, but say No Internet. Simultaneously, all my other devices are connected, o...
Jan 11, 2021Guru - Experienced User
hisself wrote:I have two PCs wired through a switch to my Orbi RBR50. In both wired and wifi modes, the PC's show connected to the router, but say No Internet. Simultaneously, all my other devices are connected, or can connect, to the internet through the same router. Also, my desktop, in another room and wired to the RBR50S satellite, connect flawlessly to the internet with a download speed of 220 Mbps.
Why does one work and the other not, even when all are wired?
hisself
Mar 22, 2021Star
Firmware 2.7.2.104
- FURRYe38Mar 22, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Are you using Traffic Meter by chance?
