cmihaly
Jul 06, 2020Tutor
Internet Connection Issues with RBK50
I just bought a Orbi RBR50+RBS50 combination to replace a nighthawk router I was using. I bought it since my nighthawk was 10 years old, was gettting flacky and had to be restarted daily, it seemed ...
Jul 06, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Has the ISP modem been powered OFF for 1 minute then back ON along with the RBR?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
