Parknuthouse's avatar
Oct 12, 2019
Internet Connection Issues
My Orbi is having internet connection issues after I changed cable modem and ISP. Connections are fine and I tried re-boot and re-install procedures with no luck. Any ideas?
  • michaelkenward's avatar
    Oct 13, 2019
    You have a new network.
    Reset the Orbi to factory defaults and set it up from  scratch.
    It needs to forget any settings inherited from the old ISP and modem.
