Parknuthouse
Oct 12, 2019Tutor
Internet Connection Issues
My Orbi is having internet connection issues after I changed cable modem and ISP. Connections are fine and I tried re-boot and re-install procedures with no luck. Any ideas?
- Oct 13, 2019
You have a new network.
Reset the Orbi to factory defaults and set it up from scratch.
It needs to forget any settings inherited from the old ISP and modem.
Parknuthouse
Oct 12, 2019Tutor
My mobile ORBI app shows no internet however the cable modem which also has it’s own network is connected and operational. ORBI router is connected to the cable modem via Ethernet cable.
ekhalil
Oct 12, 2019Master
Parknuthouse wrote:........the cable modem which also has it’s own network is connected and operational. ......
What is the make and model of the cable modem please?
