val43560
Mar 30, 2020Follower
Internet connection
My pc gets disconnected from internet every 24-48 hours. I have to reboot my computer every time to make it work. When it happens all my other devices are working fine. My pc is hard wired to Orbi and...
Mar 30, 2020Guru - Experienced User
Which Orbi model system do you have?
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Is the PCwired or wireless connected to the Orbi?
- UnCapitanoMar 30, 2020ApprenticeFurry. I appreciate your zeal in trying to find out what setup each user has, but the number of posts on this same exact issue make it clear that it isn’t a user issue at this point. As a matter of fact, the same complaints popped up on the Orbi AX side of the forums. Those have since been fixed in a beta version of firmware, at least for most users over there.
However, on the ancient RBR50, we still have no beta nor any word from Netgear. My router still needs to be reset at least once a day. That just shouldn’t happen on a platform as mature as this router now is.
