jedfsu
May 17, 2022Tutor
internet disconnecting at least once daily x several months (2??)
We moved to a new home Dec 2021. Using existing Orbi products and switched from Verizon Fios to Xfinity [due to Fios not avail where we are]. I purchase a new Motorola Cable Model MB866 DOCSIS 3.1 M...
KevinLiT
Jul 05, 2022NETGEAR Moderator
Hello jedfsu,
I understand the Motorola model you have is a modem-only configuration. In that case, the solution above will not work.
Are you able to connect a laptop or desktop computer to your modem to see if the connection is stable?
Best,
Kevin
Community Team
