nwong
Feb 25, 2020Aspirant
Internet disconnecting every 2 minutes
Just today, my internet has been disconnecting every 2 minutes on average. It disconnects for about 10-20 seconds and then reconnects back. I restarted my orbi router and satellites multiple times al...
Feb 26, 2020Guru - Experienced User
Modem you're connected to?
Is the wifi dropping or are you just getting "internet not available" notice?
Is it happening on hardwired devices too?
And if its only to the wireless is it certain satellites that are dropping?
- nwongFeb 26, 2020Aspirant
plemans wrote:Modem you're connected to?
The modem is the one provided by my ISPThe wifi just goes offline for a couple seconds
Happens to all devices (wired and non wired)
- CrimpOnFeb 26, 2020Guru - Experienced User
Questions on this forum are usually pretty specific for a reason. Knowing the brand and model of modem allows people to determine if it is a "modem", a "router/modem", or a "modem/router/wifi" box.
How the internet failure is detected is also key. i.e. the specific error message being displayed? any "colors" showing up on the Orbi?
So, "WiFI goes off" is not consistent with "happens to all devices (wired and non wired)"
Are you managing the Orbi using the web interface (web browser) or using the Orbi "app"?
CrimpOn wrote:Questions on this forum are usually pretty specific for a reason. Knowing the brand and model of modem allows people to determine if it is a "modem", a "router/modem", or a "modem/router/wifi" box.
Model is SmartRG SR515AC
There are no colors on the orbi, my wifi just disconnects for around 10-20 seconds then goes back online.
I use the orbi app
It has been working perfectly fine for almost two years now and I haven't changed anything so I am not sure why it is acting up now
