nwong
Feb 25, 2020Aspirant
Internet disconnecting every 2 minutes
Just today, my internet has been disconnecting every 2 minutes on average. It disconnects for about 10-20 seconds and then reconnects back. I restarted my orbi router and satellites multiple times al...
Retired_Member
Feb 27, 2020The one thing that amazes me with posts like this is that the history of the network is not addressed. The critical question I believe would be "how long have you had your Orbi".."has it every worked before?",..."what changes if any have you done or are aware of, such as FW updates, modems, ISP, etc.".
Without this info, most assume the problem is with some sort of device along the chain, which may be correct. However in most cases, IF the network was working fine and then one day with no action by the user it stopped, well there you go.
