IppyD
Apr 25, 2018Aspirant
Internet disconnections
Have had this system working flawless for 3 months, then disconnections to the internet happens; they are currently attached to a TP-Link 7650. Modem will be operational - no error logs, all light...
Apr 25, 2018Guru - Experienced User
Are you not getting any internet access via wired and wireless devices?
Have you walked thru the set up wizard to set up the router to the modem?
Please try a factory reset of the Orbi router and walk thru the set up wizard with the ISP modem.
- IppyDApr 25, 2018Aspirant
Internet would be working fine until everything stops loading. I'll never disconnect from the wireless network itself, it just stops receiving internet access on the network although the orbi would report the internet as "good".
Under advanced>administration>logs - Nothing out of the ordinary happens.
