IppyD
Apr 25, 2018Aspirant
Internet disconnections
Have had this system working flawless for 3 months, then disconnections to the internet happens; they are currently attached to a TP-Link 7650. Modem will be operational - no error logs, all light...
May 01, 2018Guru - Experienced User
I would try setting a manual channel on 2.4Ghz and 5Ghz. I use 1 and 48.
I also have Beamforming enabled on my orbi. All others are disabled...
What is the distance between the Orbi router and satellite?
Any other wifi neighbors near by? If so, how many?
- IppyDMay 01, 2018Aspirant
Thanks, I'll try that next disconnection if it happens. If the pattern continues, it should be tomorrow..
