IppyD
Apr 25, 2018Aspirant
Internet disconnections
Have had this system working flawless for 3 months, then disconnections to the internet happens; they are currently attached to a TP-Link 7650. Modem will be operational - no error logs, all light...
May 01, 2018Guru - Experienced User
Are these disconnections happening randomly or at specific time frames?
What is the distance between the Orbi router and satellite?
Any other wifi neighbors near by? If so, how many?
IppyD
May 01, 2018Aspirant
Specific time frame: Seems to DC every several days. Can't exactly pin point a specific time/date, as it has ocurred a day apart, some serveral days apart; all different times.
Router/Satellite distance: 2 floors up, same location vertically. Satellite has a blue ring upon connection to the router.
2.4GHz is crowded, using wifi analyzer - manually set a channel with least signal disruption.
5.0GHz isn't crowded, only one other router spotted on wifi analyzer.
