IppyD
Apr 25, 2018Aspirant
Internet disconnections
Have had this system working flawless for 3 months, then disconnections to the internet happens; they are currently attached to a TP-Link 7650. Modem will be operational - no error logs, all light...
May 02, 2018Guru - Experienced User
Let us now if changing channels helps. If your in a wifi congested area, this could be your cause...
Whats the size of your home? SqFt?
Might try reducing the power out put on the radios from High to Medium. However you'll need to move the satellite a bit closer since the signal and range from the router will be reduced..
IppyD
May 03, 2018Aspirant
Had a disconnection around 12:30AM; not as big as the other ones.
This one reconnected within seconds automtatically, so a huge improvement compared to what I was dealing with before.
