IppyD
Apr 25, 2018Aspirant
Internet disconnections
Have had this system working flawless for 3 months, then disconnections to the internet happens; they are currently attached to a TP-Link 7650. Modem will be operational - no error logs, all light...
May 03, 2018Guru - Experienced User
Might try reducing the power out put on the radios from 100% to 75% or 50%. However you'll need to move the satellite a bit closer since the signal and range from the router will be reduced..
- IppyDMay 08, 2018Aspirant
Just another disconnection just now, disconnection symptoms have gone back to normal (refusal to connect to internet without a soft reset) - router reporting internet is good, modem indicates internet as good, devices connected to the SSIDs are not receiving internet access.
Difference from last time: Beamforming and MUMIMO has been enabled, power level have been reduced to 50%Screenshots were taken during the disconnection.
