IppyD
Apr 25, 2018Aspirant
Internet disconnections
Have had this system working flawless for 3 months, then disconnections to the internet happens; they are currently attached to a TP-Link 7650. Modem will be operational - no error logs, all light...
May 03, 2018Guru - Experienced User
Might try reducing the power out put on the radios from 100% to 75% or 50%. However you'll need to move the satellite a bit closer since the signal and range from the router will be reduced..
IppyD
May 08, 2018Aspirant
Just another disconnection just now, disconnection symptoms have gone back to normal (refusal to connect to internet without a soft reset) - router reporting internet is good, modem indicates internet as good, devices connected to the SSIDs are not receiving internet access.
Difference from last time: Beamforming and MUMIMO has been enabled, power level have been reduced to 50%
Screenshots were taken during the disconnection.
