krusch00
Dec 02, 2020Guide
internet disconnects when plug in ethernet cord
i have internet on the device until i plug in an ethernet cord to go to my switch.. any ideas why?
- Dec 02, 2020
Thats why I'm curious what the modem/gateway is.
I've seen it but usually its a managed switch or double nat issue causing problems.
For every device to cause issues tends to confuse the issue a bit.
How old is the orbi?
If its within the 90 days free support window the client could contact support for free.
krusch00
Dec 02, 2020Guide
i am not on location so have limted details
the hp2810 has been factory reset.
it happens no matter what is plugged into the ethernet port
the firmware just says latest in the app.
Dec 02, 2020Guru - Experienced User
sorry, not trying to be a jerk I'm just curious. You're not at the location but you were able to try plugging in different things?
Is it all ethernet ports? just 1?
And every device hardwired in causes disconnects?
When you get to the location, modem/gateway are important as well.
And firmware numbers. the app doesn't always have devices on the latest firmware.
- krusch00Dec 02, 2020Guide
no im not there the customer is.
any switch on the port kills wan on orbi.
plugged in a different switch same thing
this is a new setup with new modem router switch router and switch factory reset
the switch and modem worked fine on the old router from their old house -- we had it plugged in for 2 days until i couuls get on location
i am trying to have him get me remote access until i can get there.
i was hoping for some general ideas or hoping someone has seen this behavior before.
- plemansDec 02, 2020Guru - Experienced User
i am past the 90 days.
i plan on going to location tonight so will have more in about 4 hours.
thanks
