DCP4971
Sep 23, 2017Luminary
Internet dropping on Orbi V2.0.0.72
V2.0.0.72 was fine initally, but I'm not overly impressed with how it handles dropping internet. I suspect my ISP supplied router is periodically (and far too frequently) dropping it's connection for...
Ely
Why would you use your ISP's supplied router when you have the Orbi? if I was you I would just disable Wi-Fi on it and run the Orbi as the router, I suspect you have a Router/Modem combo from your ISP, just disable the router part.
Also you have tried updating to V2.0.0.74 on your Orbi? .72 is no longer the latest.
- DCP4971Sep 23, 2017Luminary
Ah, the important bit that I missed.. Am using Orbi as my AP, the Cable modem is just the gateway with Wifi disabled - my suspicion is that this is dropping the internet and Orbi has been struggling to handle this.
I've installed .74 this afternoon, so seeing if that makes things more stable.
