Firebrace
Feb 15, 2020Aspirant
Internet Drops out regularly
Hi guys, I recently switched to Orbi (RBK50v2) away from my ISP supplied router. Ever since I switched my internet has not been as reliable as before. First thing I did.was updating to firmware v...
Feb 17, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Firebrace wrote:Hi guys, I recently switched to Orbi (RBK50v2) away from my ISP supplied router. Ever since I switched my internet has not been as reliable as before.
First thing I did.was updating to firmware version V2.5.1.8.
When i check the connection status this is what I get:
Lease Obtained 0 Days, 0 Hours, 5 Minutes Lease Expires 0 Days, 0 Hours, 3 Minutes
Lease time looks abnormally short. I called my ISP and they say there is nothing wrong on their end. (I am in Australia using Optus with HFC NBN).
Other thing i have tried is spoofing the mac address of the old router with no luck.
The drop out happens a few times a day and usually waiting 2-3 minutes I am back online. I'm sure its not a wireless drop out as I am still able to access the admin page during the outage.Other than this regular drop out, there isn't any other issues.
Anyone experiencing this or got any ideas?
Thanks in Advance
