davraker
Jun 03, 2020Follower
Internet freeze multiple times each hour for 10-30 seconds rbk50
I have an Orbi rbk50 and a Motorola MB8600. Mostly I have excellent speeds, but my WiFi freezes several times an hour for 10-30 seconds. It reconnects on its own and works fine till the next freeze....
Jun 03, 2020Guru - Experienced User
