apercele79
May 21, 2020Aspirant
Internet goes out every so often. Can I check whether it's my modem or my Orbi setup?
Several times a day, my internet goes out for literally a minute and then works normally as if nothing happened. But it's safe to say that it's super annoying. Am I able to check what the issue is, w...
- May 27, 2020
Glad that worked. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
apercele79
May 27, 2020Aspirant
Thanks for the very detailed reply, it ended up being my modem. I changed it that same day and havent had an issue since.
Thank you again!
May 27, 2020Guru - Experienced User
Enjoy. :smileywink:
