sanjeev40084
Mar 14, 2022Aspirant
Internet Issue on RBR40 starting Daylight saving day
I have RBR40 with latest firmware and having internet issue starting Daylight saving day. I even tried reverting old firmware and disabling traffic meter but no luck so far. There were few instances w...
- Mar 15, 2022
Please try a factory reset and setup from scratch with the RBR and RBS.
Power OFF The ISP Modem as well for 30 seconds then back on. Walk thru the setup wizard and be sure to write down all important information. Be sure not to enable Armor, Circle, Access Controls, QoS or Traffic Meter on the RBR.
KevinLiT
Mar 14, 2022NETGEAR Moderator
Hello sanjeev40084,
I am sorry to hear you are having connectivity issues with your RBR40.
Please answer the questions below so I can assist you further:
1. Is the RBR40 in access point mode?
2. Which modem are you using?
3. Are you able to access the internet when you connect laptop or PC to the RBR40?
Looking forward to your response!
Best,
Kevin
Community Team
sanjeev40084
I just checked and it is in router mode.
Spectrum Modem Model# ET2251
No.
No.
