sanjeev40084
Mar 14, 2022Aspirant
Internet Issue on RBR40 starting Daylight saving day
I have RBR40 with latest firmware and having internet issue starting Daylight saving day. I even tried reverting old firmware and disabling traffic meter but no luck so far. There were few instances w...
- Mar 15, 2022
Please try a factory reset and setup from scratch with the RBR and RBS.
Power OFF The ISP Modem as well for 30 seconds then back on. Walk thru the setup wizard and be sure to write down all important information. Be sure not to enable Armor, Circle, Access Controls, QoS or Traffic Meter on the RBR.
Mar 14, 2022Guru - Experienced User
Has Armor or Circle been enabled?
Has a factory reset been performed and setup from scratch?
- sanjeev40084Mar 14, 2022AspirantNo for all the questions.
- FURRYe38Mar 15, 2022Guru - Experienced User
Power OFF The ISP Modem as well for 30 seconds then back on. Walk thru the setup wizard and be sure to write down all important information. Be sure not to enable Armor, Circle, Access Controls, QoS or Traffic Meter on the RBR.- sanjeev40084Mar 15, 2022AspirantIs factory reset only the solution? I got tons of smart devices which I will have to reset again to connect to my wifi if it works after the factory reset :catsad:
