sanjeev40084
Mar 14, 2022Aspirant
Internet Issue on RBR40 starting Daylight saving day
I have RBR40 with latest firmware and having internet issue starting Daylight saving day. I even tried reverting old firmware and disabling traffic meter but no luck so far. There were few instances w...
- Mar 15, 2022
Please try a factory reset and setup from scratch with the RBR and RBS.
Power OFF The ISP Modem as well for 30 seconds then back on. Walk thru the setup wizard and be sure to write down all important information. Be sure not to enable Armor, Circle, Access Controls, QoS or Traffic Meter on the RBR.
sanjeev40084
No for all the questions.
Mar 15, 2022Guru - Experienced User
- sanjeev40084Mar 15, 2022AspirantIs factory reset only the solution? I got tons of smart devices which I will have to reset again to connect to my wifi if it works after the factory reset :catsad:
- Mikey94025Mar 15, 2022Hero
sanjeev40084 wrote:
Is factory reset only the solution? I got tons of smart devices which I will have to reset again to connect to my wifi if it works after the factory reset :catsad:Generally you do not need to reconfigure or redo the setup for devices as long as you keep the same SSID and security setting. Many Orbi customers replace their old router with a new Orbi router, use the same SSID, and all their smart devices still work and connect to the new Orbi wireless network.
So factory reset your Orbi, setup its wireless network in the same way and using the same SSID, and then your smart devices should connect again automatically.
- sanjeev40084Mar 17, 2022AspirantThank you everyone. The factory reset did work. I kept the same Wifi name so must of the previous connected device work without needing to reconnect. I hope I don't run into this issue again.
