smurillo1
Jul 19, 2019Tutor
Internet keeps saying offline
I just finally got everything set up and the satellites are connected but it says I'm offline. I am able to connect to the network but no internet. How can I get the system online. I can connect d...
Retired_Member
Jul 19, 2019what kind of modem do you have?
smurillo1
Jul 19, 2019Tutor
I have just the one that AT&T gave me BGW210-700
- Retired_MemberJul 19, 2019
that looks like a modem/router combo. If you MUST use it you'll need to configure the Orbi to AP mode. Tons of posts in here on how to do that.
- smurillo1Jul 19, 2019Tutor
thanks i'll check it out
It worked thanks!!
- JVitalisDec 11, 2019Aspirant
Do you have instructions on how you configured your AT&T BGW210-700 to become an IP pass through? I have yet to find a clear set of directions to make this work. Currently i have my RBR50 hardwired to the ATT box. I have the satellite connected as well. I can connect to the internet through the ORBI network but when I look at my app, it shows my network as offline.
