numzie77
Apr 25, 2025Guide
Internet not available - but only for some devices
I am running a setup with an RBR40 together with one RBS20 and one RBS40. Firmware 2.7.5.6. As of today I have this really weird problem: Our phones (two iPhones and one Google Pixel) repor...
Apr 25, 2025Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Does this happen with the RBS turned OFF?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
