ginas
Apr 06, 2020Aspirant
Internet Offline for RBR20
Can someone tell me what could be causing the Internet Offline issue? I have an RBR20 Orbi with one satellite. Just started having issues with internet last week after a year and a half. I have reboo...
- Apr 07, 2020
Ok, just checking to see if your modem had a built in router or not, it doesn't:
Power OFF the modem for 30 seconds then back on. While this is happening, press the reset button in back of the Orbi RBR for 15 seconds then release. Use a wired PC and web browser and walk thru the setup wizard at 192.168.1.1. This should help you get the RBR connected.
Be sure to use a good quality LAN cable. Swap out. CAT6 is recommended.
ginas wrote:Sorry I just logged into my Spectrum account and found this info on my Modem.ManufacturerUbeeModelE31U2V1
ekhalil
Apr 06, 2020Master
Do you get this issue intermittantly? Do you see a purple LED on the RBR20 when this happens?
If the answers are yes to those two questions, then most likely your issue is similar to this: https://community.netgear.com/t5/Orbi/Another-RBR50-Dropping-Internet-Connection/m-p/1875385/highlig...
Please try the suggested solution in that post.
- ginasApr 06, 2020Aspirant
The issue started last week and has been the same since it started. It is not intermittent. The lights on the router and satellite are like normal - they are not purple.I am able to access the apps on a laptop but not on the TV. The wesbite ittes happens on all devices. Orbi shows connected in my app but the Internet says offline.
