ginas's avatar
ginas
Internet Offline for RBR20
Can someone tell me what could be causing the Internet Offline issue? I have an RBR20 Orbi with one satellite. Just started having issues with internet last week after a year and a half. I have reboo...
  • FURRYe38's avatar
    Ok, just checking to see if your modem had a built in router or not, it doesn't:
    http://www.dslreports.com/r0/download/2360837~07f40bb37d0d67c6fd10be3e77d72927/E31_2V1%20Data%20Sheet%20Charter%201-page.pdf
    Power OFF the modem for 30 seconds then back on. While this is happening, press the reset button in back of the Orbi RBR for 15 seconds then release. Use a wired PC and web browser and walk thru the setup wizard at 192.168.1.1. This should help you get the RBR connected.
    Be sure to use a good quality LAN cable. Swap out. CAT6 is recommended.
    ginas wrote:
    Sorry I just logged into my Spectrum account and found this info on my Modem.
    Manufacturer
    Ubee
    Model
    E31U2V1
