wharfedalemfm
Apr 29, 2018Tutor
Internet port (WAN) keeps "detecting". I am driving crazy!
I had this same problem before, reported here
https://community.netgear.com/t5/Orbi/RBR50-no-internet-WAN-port-keep-quot-detecting-quot/m-p/1558686#M29251
Followed instructions in that post and t...
- May 07, 2018
For the benefit of everybody. The "detecting" problem was caused by MTU size!
Default size is 1500, which is a hair too large. I changed it to 1492. Everything is running fine for the last week. No single disruption.
I think this is ISP dependent. You can do a ping test to determine your MTU size. Just google it.
Apr 29, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT?
Cable or DSL ISP services?
wharfedalemfm
Apr 29, 2018Tutor
Arris SB6141 cable modem. ISP is Spectrum.
