WillCB12
Feb 06, 2022Aspirant
Internet Service Provider in UK
Hi I am currently with EE in the UK and they dont seem to be able to provide the configuration required to support full functionality of my Orbi Router (e.g. I cant use the Circle app as I have to s...
Feb 06, 2022Guru - Experienced User
What modem/gateway is it from EE?
What you can try doing is run their modem/gateway in router mode (disable its wifi) and put the orbi's IP address into their devices DMZ.
- WillCB12Feb 06, 2022AspirantHi. It’s an EE smart hub. I tried that suggestion before but unfortunately Wi-Fi calling kept dropping out for long periods intermittently. The only thing that worked was switching to AP mode but with that I lose parental controls.
