narvakumar
Apr 06, 2020Aspirant
Internet Speed not as per the ISP
HI, I have 50 mbps connection from ISP. But, I am getting only 0.6 mbps download and 22 mbps upload. I have updated to current firmware 2.3.5.30 still issue not solved. Regards/Narva
Apr 07, 2020Guru - Experienced User
You didn't give us much info.
1. What modem do you have? (model number)
2. What router system are you using?
3. how are you testing? wired? wireless? using the built in app or using your own app? I'd highly recommend testing wired for the most reliable results.
