narvakumar
Apr 06, 2020Aspirant
Internet Speed not as per the ISP
HI, I have 50 mbps connection from ISP. But, I am getting only 0.6 mbps download and 22 mbps upload. I have updated to current firmware 2.3.5.30 still issue not solved. Regards/Narva
Apr 07, 2020Guru - Experienced User
What is the Manufacturer and model# of the ISP modem/ONT the NG router is connected too? The RBR20 is not a modem..
narvakumar
Apr 07, 2020Aspirant
I am from Dubai. Etisalat is the ISP.
I do agree on that, as I said, If I connected directly to the Modem speed is acceptable. After connecting to the Router the speed is dropped.
- FURRYe38Apr 07, 2020Guru - Experienced User
- narvakumarApr 07, 2020Aspirant
Attached the details.
Ok, looks ISP proprietary. Was checking for a built in router here. I don't believe it has one.
