Sawdustmaker's avatar
Sawdustmaker
Internet speed problem with ORBI
I have AT&T internet and a mesh system with one main and two satellites. The download speed coming in from ATT&T is over 900, but I have buffering problems with streaming TV service, slow speeds on Mac (around 130 download). I tried turning off the ATT&T gateway wi-fi, but nothing changes. Any suggestions?
Thanks,
Paul
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last update?
    What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If the modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    h
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M9702
    • Sawdustmaker's avatar
      Sawdustmaker
      I appreciate the response, but it's a little over my head. I'm not that good with this sort of stuff. I have a friend who is, and is going to come over and use your response to see if he can help me.
      • FURRYe38's avatar
        Ok, sounds good. Let us know. :smileywink:
