Beatle45's avatar
Beatle45
Internet Speed RBR 40
My wifi speed at the cable modem is 200mbps. I can only get out of the Orbi 94 Mbps. Is there something I can do to get the speed out of the Orbi? The signal everywhere is pretty good, it is just the...
  • Beatle45's avatar
    Beatle45
    Sep 10, 2018
    Update
    I did set up the new router that was sent. In talking with Netgear we did 3. things not sure which of the 3 worked but  I went from 94mbpl to 200mbps
     Here is what we did. Changed chanel on the 5mh to 48, Dumped the app from my IPad, and reinstalled and finally replace the cord between my modem and router. Only problem now is internet drops out from my Macbook, but nothing else. I guess Orbi keeps one thinking.
