Beatle45
Aug 21, 2018Aspirant
Internet Speed RBR 40
My wifi speed at the cable modem is 200mbps. I can only get out of the Orbi 94 Mbps. Is there something I can do to get the speed out of the Orbi? The signal everywhere is pretty good, it is just the...
- Sep 10, 2018
Update
I did set up the new router that was sent. In talking with Netgear we did 3. things not sure which of the 3 worked but I went from 94mbpl to 200mbps
Here is what we did. Changed chanel on the 5mh to 48, Dumped the app from my IPad, and reinstalled and finally replace the cord between my modem and router. Only problem now is internet drops out from my Macbook, but nothing else. I guess Orbi keeps one thinking.
Aug 28, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
Keep us posted on this.
kaibab wrote:
I was told to check again in a week to see if the settings had "settled" .. We chaged the WAN MTU to 1490 instead of 1500
kaibab
Aug 28, 2018Aspirant
its a (AT&T) ARRIS/PACE 5268AC with WiFi Disabled 100Mbps
RBK50 Router and Satellite
- FURRYe38Aug 28, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.I would configure for #2. I'ts not enough to just disable the wifi on the modem
- kaibabAug 28, 2018Aspirant
FURRYe38 wrote:
Modem Combo Units:
Couple of options,
I am configured as #3 already,
Ah ok.
Which port are you using on the router to connect to the modem? WAN or LAN?
kaibab wrote:
FURRYe38 wrote:
Modem Combo Units:
Couple of options,
- Beatle45Aug 28, 2018Aspirant
Well a very long day but a productive one.
You can get a RMA by calling the Orbi support. You go through many hoops to prove you have a defective unit by changing settings, reset it to manufacture settings, and do a lot of talking on the phone I got a RMA to return for a replacement. 3 methods to get new one. 1. Send it in and wait for replacement. 2. Pay for truck delivery but you keep the unit until the new one comes then send it back. 3. Pay higher for next day shipping.
I maybe wrong but I dont think a week is going to make any differance.
Thank you for eveyone's help
FURRYe38 wrote:
Ah ok.
kaibab wrote:
FURRYe38 wrote:
Modem Combo Units:
Couple of options,
Its connected to the LAN port. Yellow Internet on Orbi-Router to LAN connection on back of modem.
