Beatle45
Aug 21, 2018Aspirant
Internet Speed RBR 40
My wifi speed at the cable modem is 200mbps. I can only get out of the Orbi 94 Mbps. Is there something I can do to get the speed out of the Orbi? The signal everywhere is pretty good, it is just the...
- Sep 10, 2018
Update
I did set up the new router that was sent. In talking with Netgear we did 3. things not sure which of the 3 worked but I went from 94mbpl to 200mbps
Here is what we did. Changed chanel on the 5mh to 48, Dumped the app from my IPad, and reinstalled and finally replace the cord between my modem and router. Only problem now is internet drops out from my Macbook, but nothing else. I guess Orbi keeps one thinking.
kaibab
Aug 28, 2018Aspirant
FURRYe38 wrote:
Any differences with using the WAN port on the router?
No difference. Always about %50 percent of the hard wired speed. I can hard wire to to the back of the Orbi router and get close to 100Mbps.. I will get back on the phone with Tech Support and see if I can get a RMA.
Thanks for everyones help
Aug 28, 2018Guru - Experienced User
Good Luck.
