LilSnoop40
Nov 11, 2017Aspirant
Internet Speed?
Hello, i have how my Orbi router/satellite combo now for about 6 months or so. not sure if i like it or what. last week i have updated my internet speed from RCN 150mbps to RCN 330mbps. i am unable...
LilSnoop40
Nov 13, 2017Aspirant
Yes, speeds from modem direct to laptop fine. Reset router, Saturday I bought the Nighthawk AC2600. Hooked it up tested the speed got max speed 360mbps no issues.
DarrenM
Nov 14, 2017Sr. NETGEAR Moderator
You could try to factory reset the orbi unit see if that works but if the unit still not getting close to the speeds you may need to contact support.
http://www.netgear.com/support/contact.aspx
DarrenM
