Teodelas
Jul 18, 2019Follower
Internet stops working once a day until a Test is done
Once a day, almost on schedule, Intenet via Orbi will stop working. Internet status says Connected. I click Test and then the Internet starts working. I've updated to the latest firmware. Any ideas wh...
CrimpOn
Jul 18, 2019Guru - Experienced User
What mode is the Orbi, router or Access Point (AP)?
What is the Orbi connected to (brand and model)? What mode is that device in? (modem only, modem/router, etc.)
Thanks
- CrimpOnJul 19, 2019Guru - Experienced User
It would also be interesting to know about the Orbi DHCP "lease". Usiing the Orbi web interface, select the Advanced Tab->Advanced Home, then click on Connection Status. It will show when the DHCP lease was obtained (some many hours/minutes/seconds ago) and when it is set to expire.
On the Advanced Tab, under Administration, there is a log file. It definitely shows when the Orbi does a "Test".
- CrimpOnJul 21, 2019Guru - Experienced User
There is another thread asking a similar question. Might be worth reading all the way to the last post.
https://community.netgear.com/t5/Orbi/rbr40-dropping-internet-connectivity/m-p/1773136#M65404
