troutteaser
Aug 07, 2019Guide
Internet throttling nightly
I have Spectrum (Charter) ISP connected to a Motorola MB7621 cable modem. My ISP service plan is 400 mbps, but I am consistently finding my internet throttled to less than 100 mbps each morning. Spe...
- Aug 26, 2019
Something to ask NG support about and see if there is any help here. IF the System really hasn't worked since you got it, maybe time to abandon it and go with something different. Sell your system to someone else if possible.
Aug 08, 2019Guru - Experienced User
Ok, this helps. At least the RBR is working by itself.
Lets try connecting just 1 of the RBS to the RBR. Lets see if the problem appears with just one RBS online. Besure to place this RBS out at least 30 feet or more.
troutteaser
Aug 09, 2019Guide
Plugged in one of the sattelites on opposite side of home (>30 feet) worked fine all day, but again found my internet service throttled back in the morning. I don't know what is going on between the RBR and RBS. I have no events logged on my modem. I do see one of my twentyfour channels that has ~2100 uncorrected packets. Again, when I reboot the Orbi all is fine until the next morning when I find my system is throttled again.
- FURRYe38Aug 09, 2019Guru - Experienced User
Sounds like the RBS is causing problems.
Try this, turn OFF the RBS.
Then go in to the RBRs web page and select remove or disconnect for the RBS seen in connected clients.
Factory reset the RBS. When the top ring is slowly pulsating WHITE, press the sync button on the RBS and RBR and let it re-add. You can do this in the same room as the RBR then once it's added, place back in remote location.
If the same problem happens again, I would make contact with NG support and see if you can get some help on this. Seems like the RBS is causing this since you tested with out them and the RBR remains good in that configuration.
- troutteaserAug 11, 2019Guide
Factory reset did not resolve the throttling issue. Since I am outside of NG's very small window of free technical support I have opted to take a chance at having both of my Orbi satellites replaced under warranty. Of course, in typical NG fashion they couldn't send me both satellites under one RMA number, so I have to pay shipping charges for each unit. If this doesn't work I will likely bite the bullet and switch to another mesh router manufacturer with better technical support. Sad, but just thinking about paying $90 to have NG "try" and figure out why their POS unit isn't working infuriates me.
- FURRYe38Aug 11, 2019Guru - Experienced User
Let us know how the RMA RBSs work. Hopefully this will fix it.
- troutteaserAug 09, 2019Guide
Also, for the one channel (#24) with uncorrected packets all the other stats look good. See attached.
