milobear19
Jan 28, 2019Aspirant
internet won't allow access to certain sites + fire stick apps/Apple TV apps
hi,
I have orbi set up and connected through our old internet modem (frontier) and I also have the orbi satellite- the connection is still not great (and we live in a two story condo) so the satell...
ekhalil
Jan 28, 2019Master
What Frontier modem/router do you have? Is it the Arris NVG448x?
If yes, then it seems that you have double routers in your network: Orbi is a router and the ISP router is another.
You need to select one of those routers as your main router:
1. If you select Orbi as the router: then you need to set the Frontier router into bridged mode/passthrough mode or DMZ forwarding.
2. If you select Frontier router as the main router: then you need to set Orbi in AP Mode.
- milobear19Jan 28, 2019Aspirant
I believe it is already in bridge mode?
is this correct?
- ekhalilJan 28, 2019MasterNot necessarily.
One quick way to test if you have double routers is to use traceroute.
Please open a Command Prompt on a computer connected -preferably wirelessly- to Orbi and type:
tracert 8.8.8.8
This will do traceroute to Google’s DNS server. If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good.- ekhalilJan 29, 2019Master
milobear19 Any progress? :)
