Cody1966
Jul 25, 2019Aspirant
Interuption after power surge
Model RBK 43 Just had a lightning strike with a power surge. My computer shows no access. The unit is solid purple. Is there an easy reset? The satellite units worked for several minutes and then...
Cody1966
I used the a paper clip. Now the unit is solid white? Do I need to do something else?
Jul 25, 2019Guru - Experienced User
Held the button in for 15 seconds?
Disconnect the Modem cable and ALL other LAN cables from the RBR and try 15 seconds again. See if the top LED will get to a slow pulsating WHITE ring on top.
IF this fails, I would contact NG support:
https://www.netgear.com/mynetgear/registration/login.aspx
- Cody1966Jul 25, 2019AspirantThe light pulsates white for about 10 seconds then stays white?
As it pulsates do I need tondo something
Else- FURRYe38Jul 25, 2019Guru - Experienced User
No should always pulsate WHITE.
Try connecting your wired pc to the back of the RBR and see if you can access 192.168.1.1...If no, I presume the RBR is bad and needs to be RMAd.- Cody1966Jul 25, 2019AspirantI currently do not have a wired PC.
Any other suggestions?
