Cody1966
Jul 25, 2019Aspirant
Interuption after power surge
Model RBK 43 Just had a lightning strike with a power surge. My computer shows no access. The unit is solid purple. Is there an easy reset? The satellite units worked for several minutes and then...
Jul 25, 2019Guru - Experienced User
Can you see the wireless default SSID name coming from the RBR?
michaelkenward
Jul 27, 2019Guru - Experienced User
It isn't clear to me that you have done the first basic steps to receiver from a power cut. Restart everything in the right order.
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
There is a chance that doing that eliminates the need for any other faffing around, including a reset. But that is probably too late now. The damage to your configuration has been done.
If none of this works, then lightning may have killed a link in the chain. Sadly, an RMA does not apply for stuff broken by lightning strikes.
